Einleitung
Is your projector overheating? Is it powering down at random times? Use this guide to replace the malfunctioning fan. Replacing the fan requires a fine tip soldering iron and should be done by those with solder experience.
Was du brauchst
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
Unsolder the red and black connections off of the motherboard.
If there are zip ties around the cables, they will need to be cut to remove the fan.
Eine weitere Person hat diese Anleitung absolviert.
