Einleitung
Muffled sound? Distorted sound? No sound? No problem! Simply use this guide to regain awesome audio in your projector. To follow this guide, you should have the following parts handy:
Was du brauchst
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
Locate the 2 screws on the handle casing. These screws are mirrored on the handle attachment on the other side panel as well.
Unscrew the two 16mm screws using the Phillips #0 screw driver. Repeat for the opposite side panel.
Lift up on the side panel and speaker attachment to slightly dislodge it.
Unscrew the four 9mm Phillips screws with a Phillips #0 screw driver, located on the outside of the projector casing.
Once the side panel door has been lifted out of the bottom casing, it can swing freely.
Rotate the side panel door forward so that you can access the screws on the speaker.
Unscrew the two 10mm screws with a Phillips #0 screw driver.
Lift the side panel and speaker out from the projector casing.
Using your hands, slide the speaker outward from the side panel.
Locate the two speaker wires connected to the sound and audio motherboard on the left panel opposite of the speaker. Unsolder these connections with a soldering iron.
Once the wires are disconnected, in order to fully remove the speaker you may need to cut the plastic bands holding the speaker wires in place.
