Zum Hauptinhalt wechseln
MerchSource the Black Series Boat Racer Battery Cable Replacement
Was du brauchst
  1. MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: Schritt 1, Bild 1 von 2 MerchSource the Black Series Boat Racer Battery Cable Replacement, Battery Cable: Schritt 1, Bild 2 von 2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery cover off.
  3. MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 3, Bild 1 von 2 MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 3, Bild 2 von 2
    • Remove both AA-batteries.
  4. MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 5, Bild 1 von 3 MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 5, Bild 2 von 3 MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 5, Bild 3 von 3
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Cable Replacement: Schritt 6, Bild 1 von 1
    • Solder the wire to reconnect it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 207
