Einleitung
This repair guide will show you how to replace the batteries in the MerchSource the Black Series Boat Racers toy boat to solve powering on issues.
Was du brauchst
Remove the screw on the top of the boat to access the battery compartment. Use a Phillips #2 screwdriver.
Remove the battery compartment cover by sliding the cover in the direction of the back of the boat to disengage the lip holding it on.
Remove the 6 screws using a Phillips #2 screwdriver. Ensure you store the screws where you will not lose them.
Remove the battery cover once all the screws are removed.
Replace with new batteries, which are 6 x AA. Make sure the positive and negative ends of the batteries align with the positive and negative connections in the battery compartment.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
