Einleitung
Use this guide to remove or replace the pump gaskets in a MiTM Air Compressor AM1HE0205HD 2014.
Was du brauchst
Ensure the compressor is unplugged.
Flip the pressure switch lever up to the off position.
Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
Use a 10 mm socket to remove the four bolts securing the pump head.
Peel the pump head gasket off of the upper valve plate.
Remove the valve plate gasket from the lower valve plate.
