Zum Hauptinhalt wechseln
Micro-USB Port Replacement
Was du brauchst
  1. Micro-USB Port Replacement, Back Plate: Schritt 1, Bild 1 von 2 Micro-USB Port Replacement, Back Plate: Schritt 1, Bild 2 von 2
    • Unscrew the four 3.4 mm flat head screws
  2. Micro-USB Port Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Micro-USB Port Replacement, Lithium Battery: Schritt 3, Bild 1 von 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Micro-USB Port Replacement: Schritt 4, Bild 1 von 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Micro-USB Port Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Micro-USB Port Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Micro-USB Port Replacement: Schritt 7, Bild 1 von 1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Micro-USB Port Replacement: Schritt 8, Bild 1 von 3 Micro-USB Port Replacement: Schritt 8, Bild 2 von 3 Micro-USB Port Replacement: Schritt 8, Bild 3 von 3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Micro-USB Port Replacement: Schritt 9, Bild 1 von 2 Micro-USB Port Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
  10. Micro-USB Port Replacement, Micro-USB Port: Schritt 10, Bild 1 von 1
    • Locate the four main soldering points marked in red.
    • Be aware of the five additional soldered pins marked by the blue arrow.
  11. Micro-USB Port Replacement: Schritt 11, Bild 1 von 3 Micro-USB Port Replacement: Schritt 11, Bild 2 von 3 Micro-USB Port Replacement: Schritt 11, Bild 3 von 3
    • Begin to desolder the points pointed out in the last step.
    • Use the soldering wick to help remove the solder.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 3-3, Baechle Fall 2016 Mitglied von IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 66
Insgesamt: 16,534
