Zum Hauptinhalt wechseln
Microsoft Surface Book Keyboard SD Card Reader Replacement
Was du brauchst
  1. Microsoft Surface Book Keyboard SD Card Reader Replacement, Remove the display with the Detach button: Schritt 1, Bild 1 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Remove the display with the Detach button: Schritt 1, Bild 2 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Remove the display with the Detach button: Schritt 1, Bild 3 von 3
    • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
    • Press and hold the Detach button on the keyboard.
    • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
    • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
    • Remove the display.
  2. Microsoft Surface Book Keyboard SD Card Reader Replacement, Manually detach the display: Schritt 2, Bild 1 von 2 Microsoft Surface Book Keyboard SD Card Reader Replacement, Manually detach the display: Schritt 2, Bild 2 von 2
    • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
    • Flip open the display as far as it will go.
    • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
  3. Microsoft Surface Book Keyboard SD Card Reader Replacement, Bend a paper clip: Schritt 3, Bild 1 von 2 Microsoft Surface Book Keyboard SD Card Reader Replacement, Bend a paper clip: Schritt 3, Bild 2 von 2
    • Straighten out one section of a paper clip.
  4. Microsoft Surface Book Keyboard SD Card Reader Replacement, Push the paper clip into the hole: Schritt 4, Bild 1 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Push the paper clip into the hole: Schritt 4, Bild 2 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Push the paper clip into the hole: Schritt 4, Bild 3 von 3
    • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
    • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
  5. Microsoft Surface Book Keyboard SD Card Reader Replacement, Release the mechanism: Schritt 5, Bild 1 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Release the mechanism: Schritt 5, Bild 2 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Release the mechanism: Schritt 5, Bild 3 von 3
    • Firmly push the paper clip into the hole.
    • This may take a considerable amount of force.
    • Once the internal lever arm is fully depressed, you can disconnect the display.
    • Pull the base away from the display to detach it.
    • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
  6. Microsoft Surface Book Keyboard SD Card Reader Replacement, Detach the second side: Schritt 6, Bild 1 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Detach the second side: Schritt 6, Bild 2 von 3 Microsoft Surface Book Keyboard SD Card Reader Replacement, Detach the second side: Schritt 6, Bild 3 von 3
    • The magnetic connections are prone to snap back into place, so hold the two halves apart.
    • With one side detached, pull firmly to pivot the display out to disconnect the second side.
    • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
  7. Microsoft Surface Book Keyboard SD Card Reader Replacement, Remove the display: Schritt 7, Bild 1 von 1
    • Completely power down your Surface Book before opening it up for any repairs.
  8. Microsoft Surface Book Keyboard SD Card Reader Replacement, Back Panel: Schritt 8, Bild 1 von 1
    • Flip the keyboard over so you can see the back panel.
  9. Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 9, Bild 1 von 2 Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 9, Bild 2 von 2
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
  10. Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 10, Bild 1 von 1
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
  11. Microsoft Surface Book Keyboard SD Card Reader Replacement, SD Card Reader: Schritt 11, Bild 1 von 1
    • Orient your keyboard with the internals facing up and the USB ports on the right.
  12. Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 12, Bild 1 von 1
    • Use the T3 screwdriver to remove the two 4 mm screws on the right side of the SD Card Reader.
  13. Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 13, Bild 1 von 2 Microsoft Surface Book Keyboard SD Card Reader Replacement: Schritt 13, Bild 2 von 2
    • Remove the black ribbon cable tab on the SD card reader from the chip with a plastic opening tool. Place the tool underneath the tab and pry it off.
    • Removing this tab can be a little difficult. Be sure that you have a good angle and do not get discouraged if removing the tab takes you multiple tries.
    • Lift the SD card reader away from the keyboard to replace it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 20-3, Livingston Fall 2016 Mitglied von Cal Poly, Team 20-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G3
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Awesome guide! Do you know where to find a replacement module?
Trent Fowler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 10
Letzten 30 Tage: 55
Insgesamt: 2,410
