Zum Hauptinhalt wechseln
Mid F900 Microphone Replacement
Was du brauchst
  1. Mid F900 Microphone Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Microphone Replacement: Schritt 2, Bild 1 von 2 Mid F900 Microphone Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Microphone Replacement, Motherboard: Schritt 3, Bild 1 von 2 Mid F900 Microphone Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Microphone Replacement: Schritt 4, Bild 1 von 2 Mid F900 Microphone Replacement: Schritt 4, Bild 2 von 2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Microphone Replacement: Schritt 5, Bild 1 von 2 Mid F900 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift and remove the motherboard from the device housing.
  6. Mid F900 Microphone Replacement, Microphone: Schritt 6, Bild 1 von 1
    • Flip the motherboard over to bring the underside into view.
    • Find and desolder the microphone near the bottom of the motherboard and remove it.
    • Solder the new microphone in its place.
    • For soldering help, check out the How to Solder and Desolder Connections guide.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matthew Oliva
364 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 6-6, Remmell Fall 2016 Mitglied von USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 114
