Einleitung
This is a guide to replace the microphone in the device. Make sure to follow all the steps correctly and handle with care.
Was du brauchst
Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
Desolder the two black and red wires connected to the motherboard.
Unclip and remove the ribbon cables attached to the motherboard.
Flip the motherboard over to bring the underside into view.
Find and desolder the microphone near the bottom of the motherboard and remove it.
Solder the new microphone in its place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
