Zum Hauptinhalt wechseln
Mid F900 Speaker Replacement
Was du brauchst
  1. Mid F900 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Speaker Replacement: Schritt 2, Bild 1 von 2 Mid F900 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Follow the black and red wires coming from the white back plate to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
    • Carefully use the soldering iron to desolder the wires from the motherboard.
    • Do not keep the soldering gun on the motherboard for too long or damage may occur to the device.
  4. Mid F900 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
    • You will need to resolder the wires from the new speaker to the motherboard.
Abschluss
Jacques Pierre
336 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-6, Remmell Fall 2016 Mitglied von USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 140
