Einleitung
To replace the screen of the Mio ALPHA 2, firstly you would need a proper repair toolkit. This is a relatively easy replacement as you would only need a Philip screwdriver with a PH0 head and tweezers. Be careful not to apply too much force or tug the cords inside.
This guide would be helpful if you're trying to replace the screen of your Mio ALPHA 2.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the four 3.8mm JIS #00 screws from the motherboard.
Remove the motherboard with tweezers
