Zum Hauptinhalt wechseln
Motherboard Replacement
Was du brauchst
  1. Motherboard Replacement, Fellowes T7CM Casing and Trigger Replacement: Schritt 1, Bild 1 von 1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
  5. Motherboard Replacement, On,  Off, Reverse Switch: Schritt 5, Bild 1 von 1
    • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
  6. Motherboard Replacement: Schritt 6, Bild 1 von 2 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the plastic switch case.
    • After the plastic case is removed, the switch can be replaced.
    • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
  7. Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Desolder the wires from the motherboard. Learn more about soldering componentshere!
  8. Motherboard Replacement: Schritt 8, Bild 1 von 1
    • After all of the wires are removed, the motherboard can be lifted off and removed with ease.
Abschluss
John Wisthoff
487 Reputation
3 Anleitungen geschrieben
IUPUI, Team 2-2, Baechle Fall 2016 Mitglied von IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 818
