Zum Hauptinhalt wechseln
Motherboard Replacement
Was du brauchst
  1. Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Motherboard Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove masking tape from the battery.
  4. Motherboard Replacement: Schritt 4, Bild 1 von 3 Motherboard Replacement: Schritt 4, Bild 2 von 3 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Motherboard Replacement: Schritt 5, Bild 1 von 3 Motherboard Replacement: Schritt 5, Bild 2 von 3 Motherboard Replacement: Schritt 5, Bild 3 von 3
  6. Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Motherboard Replacement: Schritt 8, Bild 1 von 3 Motherboard Replacement: Schritt 8, Bild 2 von 3 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team 4-1, Williams Fall 2016 Mitglied von Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 268
