Zum Hauptinhalt wechseln
Motorola Atrix 4G Motherboard Replacement
Was du brauchst
  1. Motorola Atrix 4G Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pry the back cover off the back of the phone.
  2. Motorola Atrix 4G Motherboard Replacement: Schritt 2, Bild 1 von 2 Motorola Atrix 4G Motherboard Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Spudger
    $3.99
    • Insert a spudger into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Motherboard Replacement, Antenna: Schritt 3, Bild 1 von 2 Motorola Atrix 4G Motherboard Replacement, Antenna: Schritt 3, Bild 2 von 2
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
    • Use gentle force while unscrewing to avoid stripping the screws.
  4. Motorola Atrix 4G Motherboard Replacement: Schritt 4, Bild 1 von 1
    iFixit Opening Tool
    $1.99
  5. Motorola Atrix 4G Motherboard Replacement: Schritt 5, Bild 1 von 2 Motorola Atrix 4G Motherboard Replacement: Schritt 5, Bild 2 von 2
    iFixit Opening Tool
    $1.99
    • Gently lift the tabs located at the top of the phone using an opening tool.
    • Gently lift the tab located at the bottom of the phone with the same tool.
    • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
  6. Motorola Atrix 4G Motherboard Replacement: Schritt 6, Bild 1 von 2 Motorola Atrix 4G Motherboard Replacement: Schritt 6, Bild 2 von 2
    iFixit Opening Tool
    $1.99
    • Insert an opening tool between the front and back of the case.
    • Slide the tool down the side of the phone.
    • Repeat the same process for the other side.
    • There should be a noticeable gap between the front and back cases. If not, repeat this step.
  7. Motorola Atrix 4G Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift the back case off the phone.
    • Do not completely separate the back case from the phone. The antenna is connected to both cases.
  8. Motorola Atrix 4G Motherboard Replacement: Schritt 8, Bild 1 von 1
    iFixit Opening Tool
    $1.99
    • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
    • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
  9. Motorola Atrix 4G Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Ease the antenna from out of its guide along the side of the phone
    • Remove the back case and the antenna from the phone.
    • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
  10. Motorola Atrix 4G Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 2 Motorola Atrix 4G Motherboard Replacement, Motherboard: Schritt 10, Bild 2 von 2
    Spudger
    $3.99
    • Insert a spudger between the black plastic and the motherboard.
    • Lift upwards with the spudger to dislodge the board.
    • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
  11. Motorola Atrix 4G Motherboard Replacement: Schritt 11, Bild 1 von 1
    Spudger
    $3.99
    • Disconnect the press connectors using a spudger.
    • If you are unfamiliar with using connectors, consult this guide.
  12. Motorola Atrix 4G Motherboard Replacement: Schritt 12, Bild 1 von 1
    Spudger
    $3.99
    • Lift the white latch on the ZIF connector using a spudger.
    • Gently pull the black ribbon down and away from the latch.
  13. Motorola Atrix 4G Motherboard Replacement: Schritt 13, Bild 1 von 1
    • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Derek Walker
297 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-42, Regan Spring 2012 Mitglied von Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 6,500
