Einleitung
The Baby Unit Speaker allows sound between the two units. You will need a soldering kit to successfully install a new speaker.
Was du brauchst
Using precision tweezers, remove the (4) four rubber feet from the bottom of the baby unit.
Using a Phillips #1 screwdriver remove the 9.5mm screws that were under the rubber feet.
Open the base of the baby unit.
Using the Phillips #1 screwdriver remove the 9.5mm washer head screws holding the speaker in place.
Gently lift the speaker by the wires from its plastic base.
