Zum Hauptinhalt wechseln
Motorola MC5590 Internal Antenna Replacement
Was du brauchst
  1. Motorola MC5590 Internal Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Push in the battery release button.
  2. Motorola MC5590 Internal Antenna Replacement: Schritt 2, Bild 1 von 1
    • Pull out battery.
  3. Motorola MC5590 Internal Antenna Replacement, Keyboard: Schritt 3, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement, Keyboard: Schritt 3, Bild 2 von 2
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Internal Antenna Replacement: Schritt 4, Bild 1 von 3 Motorola MC5590 Internal Antenna Replacement: Schritt 4, Bild 2 von 3 Motorola MC5590 Internal Antenna Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Internal Antenna Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Internal Antenna Replacement: Schritt 6, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 6, Bild 2 von 2
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Internal Antenna Replacement: Schritt 7, Bild 1 von 1
    • Remove the keyboard cover.
  8. Motorola MC5590 Internal Antenna Replacement: Schritt 8, Bild 1 von 3 Motorola MC5590 Internal Antenna Replacement: Schritt 8, Bild 2 von 3 Motorola MC5590 Internal Antenna Replacement: Schritt 8, Bild 3 von 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Internal Antenna Replacement: Schritt 9, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Internal Antenna Replacement, Speaker: Schritt 10, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement, Speaker: Schritt 10, Bild 2 von 2
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Internal Antenna Replacement: Schritt 11, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 11, Bild 2 von 2
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Internal Antenna Replacement: Schritt 12, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 12, Bild 2 von 2
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Internal Antenna Replacement: Schritt 13, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Internal Antenna Replacement, LCD Screen: Schritt 14, Bild 1 von 3 Motorola MC5590 Internal Antenna Replacement, LCD Screen: Schritt 14, Bild 2 von 3 Motorola MC5590 Internal Antenna Replacement, LCD Screen: Schritt 14, Bild 3 von 3
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Internal Antenna Replacement: Schritt 15, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 15, Bild 2 von 2
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Internal Antenna Replacement: Schritt 16, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 16, Bild 2 von 2
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Internal Antenna Replacement: Schritt 17, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement: Schritt 17, Bild 2 von 2
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Internal Antenna Replacement, Internal Antenna: Schritt 18, Bild 1 von 2 Motorola MC5590 Internal Antenna Replacement, Internal Antenna: Schritt 18, Bild 2 von 2
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
Abschluss
Tyler Jean
555 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 312
