Einleitung
The speaker is a vital component of your Motorola MC5590. It signifies a successful scan, and you may feel lost without it. But do not worry, because we can show you how to replace a faulty speaker!
Was du brauchst
Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the ribbon cable out of the socket.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Remove the keyboard from the device.
Remove the three Phillips #00 screws from the motherboard:
Two 3mm screws.
One 1mm screw.
