Zum Hauptinhalt wechseln
Motorola Moto 360 Rear Cover Replacement
Was du brauchst
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
    • Follow the instructions here to remove the back cover without force by using some needles in the right places:
    • Motorola Moto 360 Gehäuseverschlüsse Austausch
    • Then continue with step 5. Or don't use needles and just continue with the next steps.
  2. Motorola Moto 360 Rear Cover Replacement: Schritt 3, Bild 1 von 2 Motorola Moto 360 Rear Cover Replacement: Schritt 3, Bild 2 von 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: Schritt 4, Bild 1 von 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cole Twitchell
1.688 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-32, Amido Winter 2015 Mitglied von Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Mitglieder
18 Anleitungen geschrieben
Ein Kommentar
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 12,829
