Einleitung
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
This guide will be helpful for when you are having problems with the battery life or charging capability of the phone.
Was du brauchst
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
After removing the back panel, use the spudger to lift and detach the Battery Flux Cable from the Motherboard.
Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
Use the T4 Torx Screwdriver to remove the two 3.2 mm screws circled.
Use the Spudger to lift up and remove the Signal Flux Cable, circled in picture, from the Cable Port. The Signal Flux Cable should still be connected to the side of the phone, but detached from the charging port.
Use the Spudger to lift up and detach the Fingerprint Scanner Flux Cable from the Cable Port.
Use the Spudger to lift up and remove the Charging Port from the phone. The black box connected to the charging port will lift up with it. Remove the whole piece.
6 weitere Personen haben diese Anleitung absolviert.
