Einleitung
This guide will walk you through the process of replacing the rear camera in a Motorola Moto G4 Plus phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Continue to gently lift the back cover until all plastic clips have been released.
Remove the back cover.
Use the point of a spudger to pry up the rubber cover over the camera flash connector.
Remove the rubber cover.
Use the point of a spudger to pry up and disconnect the camera flash connector.
Loosen the midframe along the edges and lift it away from the body.
Remove the midframe.
Peel up and remove the tape securing the battery wires.
Peel up and remove the black tape that bridges the battery and the phone.
Slip the point of a spudger underneath the red and black battery wires and gently pry straight up.
Use tweezers or your fingers to de-route the battery wires from the plastic brackets.
Peel the black pull tab from battery and pull slowly but firmly to separate the battery from the frame.
Remove the battery.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using a spudger, remove the two metal pieces connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the rear camera to the motherboard.
Remove two 4.0 mm T3 Torx screws connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the motherboard to the rear camera.
2 weitere Personen haben diese Anleitung absolviert.
