Einleitung
When the Motorola G7 Play, models XT1952-3 and XT1952-2, no longer charges, it could be due to a failing charging port. This replacement guide provides efficient steps to get the device working again. If replacing the charging port doesn’t fix the issue, attempt to replace the battery with this guide.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
Using the iFixit opening tool, carefully pry up the charging port assembly cover.
Using an iFixit opening tool, detach the cables from the charging port assembly.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
