Zum Hauptinhalt wechseln
Motorola Moto Z2 Play Audio Jack Replacement
Was du brauchst
  1. Motorola Moto Z2 Play Audio Jack Replacement, Screen Removal: Schritt 1, Bild 1 von 1
    • Power off your phone before you complete any replacement steps.
  2. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 2, Bild 1 von 1
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 3, Bild 1 von 1
    • Place suction cup in the middle of the screen and press down.
  4. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 4, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 4, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 4, Bild 3 von 3
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 5, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 5, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 6, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 6, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 6, Bild 3 von 3
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  7. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 7, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 7, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 7, Bild 3 von 3
    • Identify the ribbon cable, located at the bottom right of the phone.
    • If present, remove kapton (orange) tape covering the cable connector.
    • Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
    • Excessive force is not needed.
  8. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 8, Bild 1 von 1
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  9. Motorola Moto Z2 Play Audio Jack Replacement, Battery: Schritt 9, Bild 1 von 2 Motorola Moto Z2 Play Audio Jack Replacement, Battery: Schritt 9, Bild 2 von 2
    • Remove the orange tape, located at the bottom right of the phone, using tweezers.
    • Do not discard tape.
  10. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 10, Bild 1 von 2 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 10, Bild 2 von 2
    • Detach the red and black battery wire by lifting up with tweezers.
  11. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 11, Bild 1 von 2 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 11, Bild 2 von 2
    • Peel back the black tape that is located on the battery.
    • Make sure you pull back gently so you can reuse the tape with reassembly.
  12. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 12, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 12, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 12, Bild 3 von 3
    • Lift the black tape and slide a card under the battery.
    • Align the card parallel and under the battery.
    • Wedge the card further under the battery.
    • Lift the card up to assist in removing the battery from the adhesive.
  13. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 13, Bild 1 von 1
    • Lift to remove the battery from the device completely.
  14. Motorola Moto Z2 Play Audio Jack Replacement, Audio Jack: Schritt 14, Bild 1 von 1
    • Remove the seven silver 2.6 mm T3 Torx screws on the black battery cable cover at the bottom of the phone with a screwdriver by turning counterclockwise.
    • Remove the single black 3.5 mm T3 Torx screw on the black battery cable cover at the bottom of the phone with a screwdriver by turning counterclockwise.
    • It is helpful to keep screws on a magnetic surface to avoid losing them.
  15. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 15, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 15, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 15, Bild 3 von 3
    • Lift the battery cover with tweezers starting on the right side slightly to dislodge the cover.
    • Lift the battery cover with tweezers from the left side slightly to dislodge the cover.
    • Remove the battery cover with tweezers by solidly gripping the left side of the cover and lifting up.
  16. Motorola Moto Z2 Play Audio Jack Replacement: Schritt 16, Bild 1 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 16, Bild 2 von 3 Motorola Moto Z2 Play Audio Jack Replacement: Schritt 16, Bild 3 von 3
    • Tilt the front of the black audio jack up with tweezers.
    • Lift the audio jack out of its housing with tweezers.
    • Little force is required to remove the audio jack.
Abschluss
mitch miller
2.070 Reputation
8 Anleitungen geschrieben
Cal Poly, Team S19-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 Mitglieder
30 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 2,133
