Zum Hauptinhalt wechseln
Motorola RAZR V3i Battery Replacement
Was du brauchst
  1. Motorola RAZR V3i Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: Schritt 2, Bild 1 von 3 Motorola RAZR V3i Battery Replacement: Schritt 2, Bild 2 von 3 Motorola RAZR V3i Battery Replacement: Schritt 2, Bild 3 von 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: Schritt 3, Bild 1 von 3 Motorola RAZR V3i Battery Replacement: Schritt 3, Bild 2 von 3 Motorola RAZR V3i Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Ziellinie
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Nigel
133 Reputation
2 Anleitungen geschrieben
Cuesta, Team 1-5, Zipperian Fall 2011 Mitglied von Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 61
Insgesamt: 7,211
