Zum Hauptinhalt wechseln
Motorola V190 Mini-USB Port/Motherboard Replacement
Was du brauchst
  1. Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: Schritt 1, Bild 1 von 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: Schritt 1, Bild 2 von 2
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
  2. Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: Schritt 2, Bild 1 von 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: Schritt 2, Bild 2 von 2
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
  3. Motorola V190 Mini-USB Port/Motherboard Replacement, Mini-USB Port/Motherboard: Schritt 3, Bild 1 von 1
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
  4. Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 4, Bild 1 von 3 Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 4, Bild 2 von 3 Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
  5. Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 5, Bild 1 von 3 Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 5, Bild 2 von 3 Motorola V190 Mini-USB Port/Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 214
