Einleitung
Before proceeding with the replacement guide, make sure the headphones are unplugged from any device.
  1. Remove star head screw from above base of the microphone with T6 Torx Screwdriver. To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. To expose the next screw, peel foam cover from the base toward the end of microphone.
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. With Screws removed, remove the microphone from foam and plastic cover to be inspected. If the microphone is corroded or wires are frayed, it must be replaced. If the microphone is corroded or wires are frayed, it must be replaced.
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  5. Clip both wires to remove defective microphone.
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: Wie man Lötverbindungen herstellt und entlötet
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
John Ware
325 Reputation
2 Anleitungen geschrieben
Michigan Tech, Team 5-1, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
2 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 264
