Einleitung
This guide will instruct how to install the power supply.
Was du brauchst
Use the plastic opening tool to carefully lift the rubber stops in each corner.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Find the clips that hold the antenna onto the router.
Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
The antenna may take considerable force to remove.
Unscrew the two 5 mm Phillips Head screws located at the front corners of the motherboard.
Desolder the three connections between the reset button and the motherboard
Pull the power source from the other side of the mother board once the solder is liquid.
