Zum Hauptinhalt wechseln
Neo3Do Back Panel Replacement
Was du brauchst
  1. Neo3Do Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 3 Neo3Do Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 3 Neo3Do Back Panel Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
    Frag FixBot
    Kommentar hinzufügen
  2. Neo3Do Back Panel Replacement: Schritt 2, Bild 1 von 2 Neo3Do Back Panel Replacement: Schritt 2, Bild 2 von 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
    Frag FixBot
  3. Neo3Do Back Panel Replacement: Schritt 3, Bild 1 von 2 Neo3Do Back Panel Replacement: Schritt 3, Bild 2 von 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
    Frag FixBot
  4. Neo3Do Back Panel Replacement: Schritt 4, Bild 1 von 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
    Frag FixBot
Ziellinie
USF Tampa, Team 14-3, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 400
