Zum Hauptinhalt wechseln
Neo3Do Wire Replacement
Was du brauchst
    1. Neo3Do Wire Replacement, Back Panel: Schritt 1, Bild 1 von 3 Neo3Do Wire Replacement, Back Panel: Schritt 1, Bild 2 von 3 Neo3Do Wire Replacement, Back Panel: Schritt 1, Bild 3 von 3
      • Turn the Neo3DO face down so that the logo is facing toward you.
      • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
      Frag FixBot
      Kommentar hinzufügen
    2. Neo3Do Wire Replacement: Schritt 2, Bild 1 von 2 Neo3Do Wire Replacement: Schritt 2, Bild 2 von 2
      • Gently pry the back panel upwards.
      • Ensure the tool does not slip into the device and damage the internals.
      Frag FixBot
    3. Neo3Do Wire Replacement: Schritt 3, Bild 1 von 2 Neo3Do Wire Replacement: Schritt 3, Bild 2 von 2
      • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
      Frag FixBot
    4. Neo3Do Wire Replacement: Schritt 4, Bild 1 von 1
      • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
      • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
      Frag FixBot
    1. Neo3Do Wire Replacement, Wire: Schritt 5, Bild 1 von 3 Neo3Do Wire Replacement, Wire: Schritt 5, Bild 2 von 3 Neo3Do Wire Replacement, Wire: Schritt 5, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Starting with an open back panel, take your tweezers and use them to pull back the black tabs on the connector.
      Frag FixBot
    2. Neo3Do Wire Replacement: Schritt 6, Bild 1 von 1
      • Pull the wire completely from the socket.
      • Check the metallic parts for signs of damage or corrosion. If either exists, you might need to replace the battery entirely.
      Frag FixBot
    3. Neo3Do Wire Replacement: Schritt 7, Bild 1 von 1
      • Re-insert the wire into the socket.
      Frag FixBot
    4. Neo3Do Wire Replacement: Schritt 8, Bild 1 von 3 Neo3Do Wire Replacement: Schritt 8, Bild 2 von 3 Neo3Do Wire Replacement: Schritt 8, Bild 3 von 3
      • Using the tweezers, push the black tabs back in.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 14-3, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 410
