Zum Hauptinhalt wechseln
Nest Cam Wi-Fi Cable Replacement
Was du brauchst
  1. Nest Cam Wi-Fi Cable Replacement, Wi-Fi Cable: Schritt 1, Bild 1 von 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Wi-Fi Cable Replacement: Schritt 2, Bild 1 von 3 Nest Cam Wi-Fi Cable Replacement: Schritt 2, Bild 2 von 3 Nest Cam Wi-Fi Cable Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Wi-Fi Cable Replacement: Schritt 3, Bild 1 von 3 Nest Cam Wi-Fi Cable Replacement: Schritt 3, Bild 2 von 3 Nest Cam Wi-Fi Cable Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the black Wi-Fi cable from the top of the motherboard with tweezers.
    • Use a plastic spudger to lift the motherboard and camera up enough to expose and disconnect the white cable with the tweezers.
    • Remove motherboard and camera completely from the housing.
  4. Nest Cam Wi-Fi Cable Replacement: Schritt 4, Bild 1 von 1
    • Using a soldering iron, melt away the base of the Wi-Fi cable until it can be removed. Use this guild for assistance with soldering.
    • Ensure when you solder the new cable back on that all connector ends are positioned correctly.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 1-1, Leahy Spring 2016 Mitglied von USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 Mitglieder
10 Anleitungen geschrieben
2 Kommentare zur Anleitung
I have broken the cable attached to Nest camera. Can you get replacement or repair the lead? Hope i haven't got to buy a new camera
Kerrie Davies - Antwort Teilen
I have broken lead attached to Nest camera. Can i get a replacement or repair it? Hope i havent got to buy a new camera.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 4,903
