Zum Hauptinhalt wechseln
Nest x Yale Lock Speaker Replacement
Was du brauchst
  1. Nest x Yale Lock Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Nest x Yale Lock Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Nest x Yale Lock Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Get the lock device and turn it around.
    • Take out the black cover by removing the screws as shown in picture #1 and pull it out gently just so.
    • All 3 screws are 0.25 inches high and are phillip screws.
    • Doing so gains access to the motherboard as shown in picture #3.
    Frag FixBot
    Kommentar hinzufügen
  2. Nest x Yale Lock Speaker Replacement: Schritt 2, Bild 1 von 2 Nest x Yale Lock Speaker Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • On the white connector in picture #1, push down using a pointed tip object and then remove the connection using tweezers.
    • For the wider connection in picture #2, lift up the black switch and remove the connection using tweezers.
    Frag FixBot
  3. Nest x Yale Lock Speaker Replacement: Schritt 3, Bild 1 von 2 Nest x Yale Lock Speaker Replacement: Schritt 3, Bild 2 von 2
    • Take out the motherboard by unscrewing the screws holding it shown in picture #1.
    • The screws are phillips and are 0.25 inches.
    • After removing the screw on the motherboard, pry the motherboard out using a prying tool shown in picture #2.
    Frag FixBot
  4. Nest x Yale Lock Speaker Replacement: Schritt 4, Bild 1 von 1
    • The small black part on the down right side of the motherboard is the audio.
    Frag FixBot
Abschluss
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 618
