Zum Hauptinhalt wechseln
Netgear WGR614v9 Capacitor Replacement
Was du brauchst
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: Schritt 2, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement: Schritt 2, Bild 2 von 2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: Schritt 3, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: Schritt 4, Bild 1 von 1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: Schritt 6, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement: Schritt 6, Bild 2 von 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: Schritt 7, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement, Capacitor: Schritt 7, Bild 2 von 2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: Schritt 8, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement: Schritt 8, Bild 2 von 2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: Schritt 9, Bild 1 von 2 Netgear WGR614v9 Capacitor Replacement: Schritt 9, Bild 2 von 2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: Schritt 10, Bild 1 von 3 Netgear WGR614v9 Capacitor Replacement: Schritt 10, Bild 2 von 3 Netgear WGR614v9 Capacitor Replacement: Schritt 10, Bild 3 von 3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kyle Moore
95 Reputation
1 Anleitung geschrieben
Cal Poly, Team 21-24, Maness Fall 2011 Mitglied von Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
4 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 3,211
