Zum Hauptinhalt wechseln
Nextbook NXA8QC116B Earphone Jack Replacement
Was du brauchst
  1. Nextbook NXA8QC116B Earphone Jack Replacement, Battery: Schritt 1, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement, Battery: Schritt 1, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement, Battery: Schritt 1, Bild 3 von 3
    • If you see any leakage coming from the tablet do not open the back cover!
    • Ensure you do not pry around the buttons. This could result in damage and render them inoperable.
    • •With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
  2. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 2, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Continue working the spudger downward and pry with the spudger until the bottom left-hand corner of the tablet is reached.
  3. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 3, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 3, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 3, Bild 3 von 3
    • Along the bottom of the tablet, keep using a working and prying motion with the spudger to loosen the cover.
  4. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 4, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 4, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 4, Bild 3 von 3
    • Continue prying motion until the bottom right-hand corner of the tablet is reached.
  5. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 5, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 5, Bild 2 von 2
    • Work the spudger to the upper left-hand corner of the tablet.
  6. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 6, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 6, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 6, Bild 3 von 3
    • Be careful once you get to the top of the tablet with the spudger so as not to damage the headphone jack and other ports.
    • When prying along the top of the tablet, try to keep the spudger between 70 to 85 degrees (almost perpendicular) to the tablet screen.
    • Continue working the spudger around the tablet until the cover of the device comes off
  7. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 7, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 7, Bild 2 von 2
    • Separate from the cover from the tablet.
  8. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 8, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 8, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 8, Bild 3 von 3
    • Locate and carefully remove the yellow cellophane tape from the red and black speaker wires that connect the speaker to the edge of the motherboard.
  9. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 9, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Locate and carefully remove the yellow cellophane tape with tweezers from the battery connector and black and red speaker wires on the edge of the motherboard.
  10. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 10, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 10, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 10, Bild 3 von 3
    • Using small pliers, carefully disconnect the male battery connector from the motherboard.
    • If you are only replacing the front camera, skip to step 17 in the camera replacement guide and continue.
  11. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 11, Bild 1 von 1
    • If the battery is leaking or bulging, stop and get away from it!
    • Carefully remove the gray square pad glued to both the white ribbon cable and the battery by pulling slowly.
  12. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 12, Bild 1 von 1
    • Locate the white ribbon cable Zero Insertion Force (ZIF) connector between the battery and the motherboard, and peel the yellow cellophane tape off the connector.
  13. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 13, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 13, Bild 2 von 2
    • Flip up the gray retainer clip on the white ribbon cable ZIF connector on the motherboard with your fingernail. If you do not have fingernails long enough, carefully use a black plastic spudger.
  14. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 14, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 14, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 14, Bild 3 von 3
    • Remove the white ribbon cable and carefully peel it off the battery.
  15. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 15, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 15, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 15, Bild 3 von 3
    • Move the spudger in a left-to-right scraping motion to loosen the glue until the battery is separated from the tablet.
  16. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 16, Bild 1 von 1
    • Remove the battery.
  17. Nextbook NXA8QC116B Earphone Jack Replacement, Motherboard: Schritt 17, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement, Motherboard: Schritt 17, Bild 2 von 2
    • Locate and remove the yellow cellophane tape from the display assembly ribbon cable ZIF connector.
  18. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 18, Bild 1 von 1
    • Locate the volume, power, home button ribbon cable ZIF connector.
  19. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 19, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 19, Bild 2 von 2
    • Flip the ZIF connector retainer up with your fingernail. If you do not have fingernails long enough, carefully use the black plastic spudger.
  20. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 20, Bild 1 von 1
    • Remove the ribbon cable by gently pulling on it.
  21. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 21, Bild 1 von 1
    • Locate the Display Assembly ribbon cable ZIF connector, and using tweezers, remove the yellow cellophane tape.
  22. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 22, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 22, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 22, Bild 3 von 3
    • Put your fingernail under the gray ZIF connector retainer and flip the retainer up. If you do not have fingernails long enough, carefully use a black plastic spudger.
  23. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 23, Bild 1 von 1
    • Remove the Display Assembly ribbon cable by gently pulling on it.
  24. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 24, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 24, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 24, Bild 3 von 3
    • Use small pliers to pull the connector, wiggling it a little as you pull it from its connection.
  25. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 25, Bild 1 von 2 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 25, Bild 2 von 2
    • Using a J00 screwdriver, remove the 4 black 4.0 mm screws.
    • There is no screw at this location.
  26. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 26, Bild 1 von 1
    • Locate the ZIF connector to remove the white ribbon cable
  27. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 27, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 27, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 27, Bild 3 von 3
    • To remove the white ribbon cable, put your fingernail under the gray ZIF connector retainer and flip the retainer up.
  28. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 28, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 28, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 28, Bild 3 von 3
    • Ensure the ribbon cable does not get caught when removing the motherboard. Damage to the ribbon cable may result.
    • Pull the motherboard back over the copper tape to tear the tape and remove the motherboard.
  29. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 29, Bild 1 von 1
    • Remove the remaining copper tape from the back of the display assembly and the motherboard.
    • Replace with new tape when reassembling.
  30. Nextbook NXA8QC116B Earphone Jack Replacement, Earphone Jack: Schritt 30, Bild 1 von 3 Nextbook NXA8QC116B Earphone Jack Replacement, Earphone Jack: Schritt 30, Bild 2 von 3 Nextbook NXA8QC116B Earphone Jack Replacement, Earphone Jack: Schritt 30, Bild 3 von 3
    • Please review the following link for instructions on how to use the soldering equipment to de-solder properly: Soldering Skills.
    • De-solder the earphone jack in 5 places.
  31. Nextbook NXA8QC116B Earphone Jack Replacement: Schritt 31, Bild 1 von 1
    • Remove the earphone jack.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 380
