Einleitung
It is important to note that this guide requires the use of a soldering iron. Be sure you familiarize yourself on how to use a soldering iron.
Was du brauchst
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
Pry the battery from the base using the nylon spudger and move it away from the motherboard.
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
