Einleitung
In order to access the components of your device, you will need to remove the back cover. This guide will help you accomplish this in a few simple steps.
Was du brauchst
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
Pry the battery from the base using the nylon spudger and move it away from the motherboard.
Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
Peel back metal tape that is hiding the auxiliary port wires.
Remove tape that is holding the speaker wires in place.
Lift up on the motherboard to release it from the tablet.
Flip the motherboard over and locate the Micro USB port once the motherboard has been detached
De-solder the three contact points and remove the port.
Eine weitere Person hat diese Anleitung absolviert.
