Zum Hauptinhalt wechseln
Einleitung
Use this guide to replace the antenna board on your Nexus 9.
  1. With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest. The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard. The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. This step is not necessary if you have already removed the battery. Carefully peel up the copper shielding with your fingers.
    • This step is not necessary if you have already removed the battery.
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
  4. Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
Abschluss
Geoff Wacker
85.117 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 1,267
