Zum Hauptinhalt wechseln
Nexus 9 Front Facing Camera Replacement
Was du brauchst
    1. Nexus 9 Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 1 von 3 Nexus 9 Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 2 von 3 Nexus 9 Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 3 von 3
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Frag FixBot
      Kommentar hinzufügen
    1. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: Schritt 2, Bild 1 von 1
      In diesem Schritt verwendetes Werkzeug:
      • Use a spudger to disconnect the front-facing camera ZIF connector.
      • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 49
Insgesamt: 1,245
