Zum Hauptinhalt wechseln
Nike+ Sportband Battery Replacement
Was du brauchst
  1. Nike+ Sportband Battery Replacement, External Case: Schritt 1, Bild 1 von 2 Nike+ Sportband Battery Replacement, External Case: Schritt 1, Bild 2 von 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Battery Replacement: Schritt 2, Bild 1 von 2 Nike+ Sportband Battery Replacement: Schritt 2, Bild 2 von 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Battery Replacement, Screen: Schritt 3, Bild 1 von 2 Nike+ Sportband Battery Replacement, Screen: Schritt 3, Bild 2 von 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Battery Replacement: Schritt 4, Bild 1 von 3 Nike+ Sportband Battery Replacement: Schritt 4, Bild 2 von 3 Nike+ Sportband Battery Replacement: Schritt 4, Bild 3 von 3
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Battery Replacement: Schritt 5, Bild 1 von 2 Nike+ Sportband Battery Replacement: Schritt 5, Bild 2 von 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Battery Replacement: Schritt 6, Bild 1 von 3 Nike+ Sportband Battery Replacement: Schritt 6, Bild 2 von 3 Nike+ Sportband Battery Replacement: Schritt 6, Bild 3 von 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Battery Replacement, Motherboard: Schritt 7, Bild 1 von 1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Battery Replacement: Schritt 8, Bild 1 von 3 Nike+ Sportband Battery Replacement: Schritt 8, Bild 2 von 3 Nike+ Sportband Battery Replacement: Schritt 8, Bild 3 von 3
    • Use the metal tweezers to lift the motherboard out of the device.
  9. Nike+ Sportband Battery Replacement, Battery: Schritt 9, Bild 1 von 2 Nike+ Sportband Battery Replacement, Battery: Schritt 9, Bild 2 von 2
    • Slowly lift the motherboard off of the mounting body of the band with a pair of tweezers.
  10. Nike+ Sportband Battery Replacement: Schritt 10, Bild 1 von 1
    • Gently lay the motherboard upside down exposing the underside of the motherboard.
    • The red and black battery wires may need to be desoldered from the board. Check out the How To Solder and Desolder Connections guide for some helpful tips on this.
    • Using the flat edge of a spudger separate the battery from the body of the band.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alyssa Setnar
331 Reputation
3 Anleitungen geschrieben
IUPUI, Team 9-9, Wilson Spring 2016 Mitglied von IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 2,183
