Zum Hauptinhalt wechseln
Nikon Coolpix 5400 Battery Door Replacement
Was du brauchst
  1. Nikon Coolpix 5400 Battery Door Replacement, Battery Door: Schritt 1, Bild 1 von 1
    • Remove one 3mm Phillips #0 screw from the top of the camera back cover.
  2. Nikon Coolpix 5400 Battery Door Replacement: Schritt 2, Bild 1 von 1
    • Remove three 3mm Phillips #0 screws from the side of the back cover.
  3. Nikon Coolpix 5400 Battery Door Replacement: Schritt 3, Bild 1 von 1
    • Lift memory card flap.
    • Remove one 3mm Phillips #0 screw from the side of the back case.
  4. Nikon Coolpix 5400 Battery Door Replacement: Schritt 4, Bild 1 von 1
    • Remove four 3mm Phillips #0 screws from the bottom of the back case.
  5. Nikon Coolpix 5400 Battery Door Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix 5400 Battery Door Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to gently pop the back case away from the body of the camera.
    • Pull the back case away from the camera very gently.
    • The connecting cables are very fragile and easily broken.
  6. Nikon Coolpix 5400 Battery Door Replacement: Schritt 6, Bild 1 von 1
    • Flip camera over so the bottom is facing up.
    • Push the sliding latch to open the battery door.
    • Push the press fit pin firmly with a flat-head screwdriver to release it from the hinge housing.
    • Push to the left, half the length of the pin.
  7. Nikon Coolpix 5400 Battery Door Replacement: Schritt 7, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Grasp the press fit pin firmly with precision tweezers to pull it from the housing.
    • Do not to drop the pin into the camera body.
  8. Nikon Coolpix 5400 Battery Door Replacement: Schritt 8, Bild 1 von 1
    • Remove the battery door by lifting it out of the camera body.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 240
