Zum Hauptinhalt wechseln
Nikon Coolpix AW130 Motherboard Replacement
Was du brauchst
  1. Nikon Coolpix AW130 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Motherboard Replacement: Schritt 2, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Motherboard Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Motherboard Replacement, Front Panel: Schritt 5, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement, Front Panel: Schritt 5, Bild 2 von 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Motherboard Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Motherboard Replacement, Back Panel: Schritt 7, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement, Back Panel: Schritt 7, Bild 2 von 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  8. Nikon Coolpix AW130 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  9. Nikon Coolpix AW130 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  10. Nikon Coolpix AW130 Motherboard Replacement: Schritt 10, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  11. Nikon Coolpix AW130 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Carefully remove the back cover from the camera body.
  12. Nikon Coolpix AW130 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 2 Nikon Coolpix AW130 Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Using a Phillips #000 screwdriver, remove all 8, 4mm screws on the motherboard.
  13. Nikon Coolpix AW130 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Using the nylon spudger tool, peel back the metallic plate.
    • A metal spudger is shown in the photo, but a nylon spudger should be used.
    • Do not rip the gold-colored ribbons.
  14. Nikon Coolpix AW130 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Using your fingers, carefully disconnect the connector ribbons.
    • Though various guides suggest using a plastic or metal spudger tool to disconnect the ribbons, this tool is liable to damage the connectors.
  15. Nikon Coolpix AW130 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the black piece on the lefthand side.
  16. Nikon Coolpix AW130 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • On the remaining piece, desolder the labeled soldering points.
    • The soldering tool can get extremely hot. For soldering help, check out iFixit's guide for How to Solder and Desolder Connections.
  17. Nikon Coolpix AW130 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Flip the remaining piece over, careful not to rip any of the connecting wires.
  18. Nikon Coolpix AW130 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Desolder at the prescribed sites.
    • Remove the motherboard from the camera body.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Lauren Stepp
1.251 Reputation
8 Anleitungen geschrieben
Ein Kommentar
Thanks for this guide.
I managed to open 2 of theses and swap the sensor-unit from one to another.
Unluckily the camera remains broken since one only shows a black picture - even though the sensor is alright an the other has a broken AF from a fall, I suppose...
I am certain with some silicone grease on the orange rubber the camera would still be waterproof.
Daniel Bardua - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 50
Insgesamt: 5,179
