Zum Hauptinhalt wechseln
Nikon Coolpix P90 Flash Bulb Replacement
Was du brauchst
  1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: Schritt 1, Bild 1 von 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: Schritt 1, Bild 2 von 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: Schritt 1, Bild 3 von 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: Schritt 2, Bild 1 von 2 Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: Schritt 2, Bild 2 von 2
    • Press the button on the side of the body to open the flash compartment.
  3. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the compartment.
  4. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 4, Bild 1 von 1
    • Place the plastic opening tool along the crack on the side of the flash compartment cover and pry open and detach the cover.
  5. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 5, Bild 1 von 2 Nikon Coolpix P90 Flash Bulb Replacement: Schritt 5, Bild 2 von 2
    • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
    • Detach the plastic cover.
  6. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 6, Bild 1 von 2 Nikon Coolpix P90 Flash Bulb Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the flash bulb holder with your fingers.
  7. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 7, Bild 1 von 1
    • Using the plastic opening tool, pry the metal bulb frame out of the socket.
  8. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 8, Bild 1 von 1
    • Remove the plastic stoppers on either side of the metal flash bulb tray.
  9. Nikon Coolpix P90 Flash Bulb Replacement: Schritt 9, Bild 1 von 1
    • Using a soldering iron, desolder each of the wires connected to the light bulb.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
Abschluss
Cal Poly, Team 20-14, Maness Winter 2015 Mitglied von Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 850
