Was du brauchst
Remove six 3 mm x 2.5 mm Phillips head screws from the bottom of the camera.
Remove three 3 mm x 5.5 mm Phillips head screws from the bottom of the camera near the battery cover.
Lift the battery cover and remove two 3 mm x 5.5 mm Phillips head screws as shown.
Remove the bottom cover.
Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and on either side of the SD card slot cover.
Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
Lift the LCD panel off up to expose a ribbon connector. Then lift the ribbon connector tab as shown and slide the ribbon out.
Lift the LCD panel away and off the camera
Remove six 3 mm x 5.5 mm Phillips head screws from around the lens ring and remove the lens ring.
Remove two 2.5 mm x 4 mm Phillips head screws from above the lens ring to allow the front of the camera to be removed.
Lift and remove the grip and the front panel of the camera.
Remove two 3 mm x 4 mm Phillips head screws from where the camera grip was just removed.
Remove one 2 mm x 3 mm Phillips head screw from the same location as above.
Remove one 3 mm x 5.5 mm Phillips head screw from the top right side of the camera shown.
Remove one 3 mm x 3 mm Phillips head screw from the top left side of the camera shown.
Gently lift the top of the camera up to separate it from the main body of the camera. At this point, it will still be connected via wires.
De-solder the wire shown on the grip side of the camera to allow sufficient access to the top of the camera.
Remove the ribbon connector.
Remove the 3 mm x 4 mm Phillips head screw and lift off the plastic bracket to expose the on/off switch underneath.
Remove the two 2 mm x 4 mm Phillips head screws and the shutter button and on/off switch will fall down away from the top of the panel.
4 weitere Personen haben diese Anleitung absolviert.
