Einleitung
If your Nikon D3100 LCD screen is cracked, chipped, or flickering it may need to be replaced. Follow this guide to replace the LCD screen. But first take a look at this troubleshooting page to check if the problem is truly the LCD screen and not a setting issue.
Was du brauchst
Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
Remove the 3mm screw behind the rubber grip on the top right of the back panel.
Peel back the rubber grip on the right side of the camera using a spudger.
Remove two of the 5mm screws under the rubber grip.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
Separate the back panel from the main body of the camera.
Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
7 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Very helpful guide, so happy to have a non-cracked screen again!
now, where can i buy this replacement screen here in the Philippines?
does anyone have the part number for the replacement screen?
Hello, regarde ici ça devrait correspondre:
