Einleitung
The LCD unit is the main component of the digital display on the D5100. This guide will teach you how to remove and replace it.
Ersatzteile
Keine Ersatzteile angegeben.
Using a screwdriver, remove the four screws around the perimeter of the LCD panel.
Using a fingernail or the flat edge of a spudger inserted into the seam, separate the LCD bevel from the main panel body.
Remove the ribbon cables on the LCD's circuitboard by flipping up their plastic clasps and removing it from their casing.
Disconnect the 16-pin cable by gently pulling it upward, away from the circuitboard, until it is removed from its port.
Desolder the 3 wires (red, yellow, and black) connecting the LCD board to the main camera body.
The LCD assembly can now be fully separated from the main camera body.
Remove the plastic bezel and metal bracket from the LCD itself to complete the removal process.
7 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
Thanks for this Liz.
Removing the broken LCD from my Nikon D5100 seems like something I can do now!
I am unsure ?how to do the soldering bit to attach the new LCD, ?where to attach the wires...
Any help is welcome
I was able to fix it, thanks to you guys. But the colors that came on the, LCD are weird. At least I can see the image.
I am having trouble reconnecting the 16-pin cable to the circuit board. Do you have any tips?
Thank you! I had talked to a camera shop and they said the cost of the crystal would be so much I should buy a new camera…. The crystal was 54.00 and i just need my personal time and labor. THANK YOU!!!
