Einleitung
Use this guide to replace the eyepiece cover that allows for focus compensation.
  1. Use your finger tip to pull the battery release tab toward the center of the D70.
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Pull the battery out of the D70.
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Remove the following eight screws securing the bottom cover to the D70:
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Carefully pull the bottom cover to separate it from the body of the D70. Remove the bottom cover from the D70.
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  6. Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  7. Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  8. Carefully pull the sides of the rear cover away from the body of the D70. Carefully pull the sides of the rear cover away from the body of the D70.
    • Carefully pull the sides of the rear cover away from the body of the D70.
  9. Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught. At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  10. Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
    • Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
  11. Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  12. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  13. Remove the two 4.3 mm Phillips screws on the face of the front cover.
    • Remove the two 4.3 mm Phillips screws on the face of the front cover.
  14. Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
    • Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
  15. Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch. Pull the automatic/manual focus switch away from the front cover.
    • Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
    • Pull the automatic/manual focus switch away from the front cover.
  16. If present, remove the plastic cover from the lens mount.
    • If present, remove the plastic cover from the lens mount.
  17. Pull the front cover away from the D70.
    • Pull the front cover away from the D70.
  18. Remove the 5.7 mm Phillips screw in the top corner of the battery compartment.
    • Remove the 5.7 mm Phillips screw in the top corner of the battery compartment.
  19. Remove the 4.2 mm Phillips screw securing the lower edge of the grip to the front of the D70.
    • Remove the 4.2 mm Phillips screw securing the lower edge of the grip to the front of the D70.
  20. Remove the grip from the D70. Do not touch any of the exposed solder points under the grip, as the capacitor is attached in this area. The attachment points for the blue and pink leads of the capacitor are circled in yellow in the second picture.
    • Remove the grip from the D70.
    • Do not touch any of the exposed solder points under the grip, as the capacitor is attached in this area. The attachment points for the blue and pink leads of the capacitor are circled in yellow in the second picture.
  21. Remove the silver Phillips screw securing the port cover to the side of the D70. Remove the port cover from the D70.
    • Remove the silver Phillips screw securing the port cover to the side of the D70.
    • Remove the port cover from the D70.
  22. Touch the bare leads of a capacitor discharge tool to the pink and blue capacitor leads soldered to the circuit board near the AF lamp. At this point, the capacitor should be discharged. Avoid touching the bare leads to prevent a shock if the capacitor is still partially charged.
    • Touch the bare leads of a capacitor discharge tool to the pink and blue capacitor leads soldered to the circuit board near the AF lamp.
    • At this point, the capacitor should be discharged. Avoid touching the bare leads to prevent a shock if the capacitor is still partially charged.
  23. Carefully de-solder the black, grey, white, and orange leads (boxed in red) from the side of the circuit board near the AF lamp. Lightly heat the joint of each lead with a soldering iron as you apply slight tension to the wire with a pair of tweezers. Do not excessively heat the board. Also, be sure not to accidentally melt the plastic case with the side of the soldering iron.
    • Carefully de-solder the black, grey, white, and orange leads (boxed in red) from the side of the circuit board near the AF lamp.
    • Lightly heat the joint of each lead with a soldering iron as you apply slight tension to the wire with a pair of tweezers.
    • Do not excessively heat the board. Also, be sure not to accidentally melt the plastic case with the side of the soldering iron.
    • Repeat the process until all four leads are de-soldered.
  24. In this step, you will de-solder the four wires pictured. Mark the wires with a sharpie or a paint marker to keep track of their locations, as each pair of leads is nearly identical.
    • In this step, you will de-solder the four wires pictured. Mark the wires with a sharpie or a paint marker to keep track of their locations, as each pair of leads is nearly identical.
    • De-solder the four wires boxed in red using the same procedure on the preceding step.
    • Do not apply too much heat to the joints as you de-solder, as the ribbon cable they are soldered to is extremely delicate and melts easily.
  25. If present, remove the piece of tape covering the ribbon cable socket (boxed in red).
    • If present, remove the piece of tape covering the ribbon cable socket (boxed in red).
  26. Use your fingernail to flip up the ZIF retaining flap. Make sure you are prying up on the ZIF retaining flap, not the socket itself.
    • Use your fingernail to flip up the ZIF retaining flap.
    • Make sure you are prying up on the ZIF retaining flap, not the socket itself.
    • Pull the ribbon cable straight out of its socket.
  27. Remove the Phillips screw securing the top cover to the D70 near the mode dial.
    • Remove the Phillips screw securing the top cover to the D70 near the mode dial.
  28. Remove the following two screws securing the top cover to the D70 near the shutter button:
    • Remove the following two screws securing the top cover to the D70 near the shutter button:
    • One black 4.8 mm Phillips screw
    • One silver 4.2 mm Phillips screw
  29. Remove the two 7.3 mm Phillips screws securing the top case to the D70 near the eyepiece.
    • Remove the two 7.3 mm Phillips screws securing the top case to the D70 near the eyepiece.
  30. Remove the 4.7 mm Phillips screw from under the top cover near the shutter button.
    • Remove the 4.7 mm Phillips screw from under the top cover near the shutter button.
  31. De-solder the thin black wire (boxed in red) from the DC/DC board.
    • De-solder the thin black wire (boxed in red) from the DC/DC board.
    • Do not heat up the DC/DC board too much during the process.
  32. Carefully lift the top cover near the mode dial as you pull the mode dial ribbon cable away from the lens base. Remove the top cover from the D70, minding any cables that may get caught.
    • Carefully lift the top cover near the mode dial as you pull the mode dial ribbon cable away from the lens base.
    • Remove the top cover from the D70, minding any cables that may get caught.
  33. Carefully remove the eyepiece from the D70.
    • Carefully remove the eyepiece from the D70.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Eyepiece Remove/Instal Step 32. To remove or replace the eyepiece, the diopter adjustment slider should be pushed fully to the '-' setting; that is, towards the base of the camera.
SaltyOne - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 12,090
