Zum Hauptinhalt wechseln
Nikon D7000 Image Sensor Replacement
Was du brauchst
  1. Nikon D7000 Image Sensor Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
    Frag FixBot
    Kommentar hinzufügen
  2. Nikon D7000 Image Sensor Replacement: Schritt 2, Bild 1 von 1
    • Remove three 6 mm J000 screws from under the battery cover.
    Frag FixBot
  3. Nikon D7000 Image Sensor Replacement: Schritt 3, Bild 1 von 2 Nikon D7000 Image Sensor Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the bottom cover off of the camera body.
    Frag FixBot
  4. Nikon D7000 Image Sensor Replacement: Schritt 4, Bild 1 von 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
    Frag FixBot
  5. Nikon D7000 Image Sensor Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Peel the rear rubber piece off with tweezers.
    Frag FixBot
  6. Nikon D7000 Image Sensor Replacement: Schritt 6, Bild 1 von 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    Frag FixBot
  7. Nikon D7000 Image Sensor Replacement: Schritt 7, Bild 1 von 1
    • Pull the eyepiece cover up to remove it.
    Frag FixBot
  8. Nikon D7000 Image Sensor Replacement: Schritt 8, Bild 1 von 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    Frag FixBot
  9. Nikon D7000 Image Sensor Replacement: Schritt 9, Bild 1 von 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
    Frag FixBot
  10. Nikon D7000 Image Sensor Replacement: Schritt 10, Bild 1 von 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
    Frag FixBot
  11. Nikon D7000 Image Sensor Replacement: Schritt 11, Bild 1 von 1
    • Gently pull the SD card cover off.
    Frag FixBot
  12. Nikon D7000 Image Sensor Replacement: Schritt 12, Bild 1 von 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
    Frag FixBot
  13. Nikon D7000 Image Sensor Replacement: Schritt 13, Bild 1 von 1
    • Carefully lift the back case off.
    Frag FixBot
  14. Nikon D7000 Image Sensor Replacement: Schritt 14, Bild 1 von 3 Nikon D7000 Image Sensor Replacement: Schritt 14, Bild 2 von 3 Nikon D7000 Image Sensor Replacement: Schritt 14, Bild 3 von 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
    Frag FixBot
  15. Nikon D7000 Image Sensor Replacement: Schritt 15, Bild 1 von 2 Nikon D7000 Image Sensor Replacement: Schritt 15, Bild 2 von 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
    Frag FixBot
  16. Nikon D7000 Image Sensor Replacement: Schritt 16, Bild 1 von 1
    • Gently pry and lift the left motherboard shield off.
    Frag FixBot
  17. Nikon D7000 Image Sensor Replacement: Schritt 17, Bild 1 von 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    Frag FixBot
  18. Nikon D7000 Image Sensor Replacement: Schritt 18, Bild 1 von 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
    Frag FixBot
  19. Nikon D7000 Image Sensor Replacement: Schritt 19, Bild 1 von 3 Nikon D7000 Image Sensor Replacement: Schritt 19, Bild 2 von 3 Nikon D7000 Image Sensor Replacement: Schritt 19, Bild 3 von 3
    • Disconnect remaining ribbon cables.
    Frag FixBot
  20. Nikon D7000 Image Sensor Replacement: Schritt 20, Bild 1 von 2 Nikon D7000 Image Sensor Replacement: Schritt 20, Bild 2 von 2
    Frag FixBot
  21. Nikon D7000 Image Sensor Replacement: Schritt 21, Bild 1 von 1
    • Carefully disconnect the red connector with tweezers.
    Frag FixBot
  22. Nikon D7000 Image Sensor Replacement: Schritt 22, Bild 1 von 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
    Frag FixBot
  23. Nikon D7000 Image Sensor Replacement: Schritt 23, Bild 1 von 1
    • Gently pull the port side cover away from the motherboard.
    Frag FixBot
  24. Nikon D7000 Image Sensor Replacement: Schritt 24, Bild 1 von 1
    • Lift the motherboard off.
    Frag FixBot
  25. Nikon D7000 Image Sensor Replacement, Image Sensor: Schritt 25, Bild 1 von 2 Nikon D7000 Image Sensor Replacement, Image Sensor: Schritt 25, Bild 2 von 2
    • Disconnect black and white speaker cable.
    Frag FixBot
  26. Nikon D7000 Image Sensor Replacement: Schritt 26, Bild 1 von 1
    • Remove three 6 mm J000 screws securing the image sensor.
    Frag FixBot
  27. Nikon D7000 Image Sensor Replacement: Schritt 27, Bild 1 von 1
    • Carefully lift the image sensor plate out of the camera.
    Frag FixBot
Abschluss
20 weitere Personen haben diese Anleitung absolviert.
Jed Chen
1.865 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 24-6, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Mitglieder
6 Anleitungen geschrieben
4 Kommentare zur Anleitung
I really need to do this operation! One question: I’m shopping for a replacement sensor and in the photos it looks like the cables off the sensor assembly are free hanging. In this tutorial there is only the disconnection of the black and white speaker cables. Where do these cables go?
Sean McDonald - Antwort Teilen
I am grateful for this! Thanks - it worked a treat!
Peter Davies - Antwort Teilen
Thanks, I have done it with the Nikon d7200, it is different I have made some comments already, similar to the Nikon d7100 you have to unscrew the diopter and has 2 screws under the rubber what you have to remove… The motherboard is totally different
Rudi Zimmerer - Antwort Teilen
Any suggestions for locating a reputable, OEM part? Tons of choices on eBay with widely varying prices. Hints or clues to ensure I am buying authentic and safe parts are appreciated! Thanks!
George Peters - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 66
Insgesamt: 11,984
