Zum Hauptinhalt wechseln
Nikon D80 Main Board Replacement
Was du brauchst
  1. Nikon D80 Main Board Replacement, Main Board: Schritt 1, Bild 1 von 2 Nikon D80 Main Board Replacement, Main Board: Schritt 1, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: Schritt 2, Bild 1 von 3 Nikon D80 Main Board Replacement: Schritt 2, Bild 2 von 3 Nikon D80 Main Board Replacement: Schritt 2, Bild 3 von 3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: Schritt 3, Bild 1 von 3 Nikon D80 Main Board Replacement: Schritt 3, Bild 2 von 3 Nikon D80 Main Board Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: Schritt 4, Bild 1 von 2 Nikon D80 Main Board Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: Schritt 5, Bild 1 von 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: Schritt 6, Bild 1 von 3 Nikon D80 Main Board Replacement: Schritt 6, Bild 2 von 3 Nikon D80 Main Board Replacement: Schritt 6, Bild 3 von 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sara Martin
577 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G1, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 41
Insgesamt: 2,221
