Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
On the bottom of the camera,
remove the two 5.3mm Phillips screws
and the other two 6.3mm Phillips screws.
Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
Lift the rear case off of the back of the camera.
Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
8 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
good guidance,easy to follow,thanks
I want to replace my Nikon D90 DSLR bad LCD, this guide will save me from costly repairs.
