Einleitung
If you notice the LED lights on your device are continuously blinking or not working at all, this step-by-step guide will show you how to replace them individually, or all together. For soldering help, follow the How to Solder and Desolder Connections guide.
Was du brauchst
On the circuit board, locate the LED light you wish to replace.
On the bottom of the board, each LED is designated with a small triangle with a line at one tip and a label of LED1, LED2, etc.
Desolder the two LED leads to the specific bulb.
Remove the LED from the circuit board.
Properly install the new LED and solder to the board.
