Zum Hauptinhalt wechseln
Ninja Mega Kitchen System BL770 LED Light Replacement
Was du brauchst
  1. Ninja Mega Kitchen System BL770 LED Light Replacement, LED Light: Schritt 1, Bild 1 von 2 Ninja Mega Kitchen System BL770 LED Light Replacement, LED Light: Schritt 1, Bild 2 von 2
    • On the circuit board, locate the LED light you wish to replace.
    • On the bottom of the board, each LED is designated with a small triangle with a line at one tip and a label of LED1, LED2, etc.
  2. Ninja Mega Kitchen System BL770 LED Light Replacement: Schritt 2, Bild 1 von 1
    • Desolder the two LED leads to the specific bulb.
    • Remove the LED from the circuit board.
    • Properly install the new LED and solder to the board.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 615
