Zum Hauptinhalt wechseln
Nintendo DSi XL Stylus Housing Replacement
Was du brauchst
  1. Nintendo DSi XL Stylus Housing Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DSi XL Stylus Housing Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Stylus Housing Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Stylus Housing Replacement, Lower Case: Schritt 3, Bild 1 von 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: Schritt 3, Bild 2 von 3 Nintendo DSi XL Stylus Housing Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Stylus Housing Replacement: Schritt 4, Bild 1 von 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Stylus Housing Replacement: Schritt 5, Bild 1 von 3 Nintendo DSi XL Stylus Housing Replacement: Schritt 5, Bild 2 von 3 Nintendo DSi XL Stylus Housing Replacement: Schritt 5, Bild 3 von 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Stylus Housing Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi XL Stylus Housing Replacement: Schritt 6, Bild 2 von 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Stylus Housing Replacement: Schritt 7, Bild 1 von 2 Nintendo DSi XL Stylus Housing Replacement: Schritt 7, Bild 2 von 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: Schritt 8, Bild 1 von 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: Schritt 8, Bild 2 von 3 Nintendo DSi XL Stylus Housing Replacement, Right Shoulder Button: Schritt 8, Bild 3 von 3
    • Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
    • Lift the right shoulder button assembly from the back case.
    • The components of the right shoulder button assembly:
    • Right shoulder button
    • Shoulder button spring
    • Retaining pin
    • Right shoulder button holding panel
  9. Nintendo DSi XL Stylus Housing Replacement, Stylus Housing: Schritt 9, Bild 1 von 1
    • Remove the stylus from its housing on the right side of the DSi XL.
  10. Nintendo DSi XL Stylus Housing Replacement: Schritt 10, Bild 1 von 3 Nintendo DSi XL Stylus Housing Replacement: Schritt 10, Bild 2 von 3 Nintendo DSi XL Stylus Housing Replacement: Schritt 10, Bild 3 von 3
    • Remove the three 4 mm gold Phillips screws securing the stylus housing to the lower case.
    • Using a spudger, lift the stylus housing off the lower case.
    • Remove the stylus housing from the handheld console.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Brett Hartt
128.242 Reputation
143 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
140 Mitglieder
18.076 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 7,812
